Wow, 3 weeks since my last message, time flies ! At that rate I will be 6 feet under in no time !
I spent all week-end on the thing...
I put it back together, it's all in one piece now... the bench is now much less messy, a good thing.
Cooling fanI started with that. I tried to straighten the motor bracket so that the fan sit more upright and stops hitting the air filter/grill, which was a show stopper previously. It's not that easy but the little bit that I managed to achieve, coupled with massaging the fan blades so they are about equal, did the trick.
Runs quietly now, no more hitting. Other problem was the fan shroud that was not oriented / clocked properly. There is a big flat on it so there is only one way to orient it properly. So I tried to do that and... oh, something is wrong. You can do it because if you do, the wires coming out of the motor are now too short to get to the ceramic strip onto which they are soldered. Hmmm.. so that means whoever messed with that fan, must have removed the motor and clocked it incorrectly on its bracket when putting it back in place, making the wires now too short... forcing him to correct that by instead messing with the orientation of the shroud. So I removed the motor... its two retaining nuts were barely finger tight ! Yes, no doubt, someone was in there... The shroud is now oriented as it should, I can tick that problem off the list...
So then that meant I had access to all 4 mounting holes for the grill. Previously only two holes were accessible because of the shroud problem, so the guy put only 2 screws back in. Sadly I was able to only put 3 out of 4 screws.. the last one would not bite, guy messed also with that apparently, he must have damaged the "thread" (it's a self taper screw). So yeah, this whole fan thing was quite a fuckery. Now much better.
CRT rotation mechanism-tektronix-502-scope-repair-restoration/?action=dlattach;attach=2485749;image)
The white nylon clamp was broken in two, snapped, as mentioned earlier. So I replaced it. I did it in situ which proved to be quite a challenge, took some fiddling...
Doing so, I noticed yet another difference between the 502 and 502A. In the 502A, as logic would dictate, the worm screw is held at both of its extremities, so it's held in place properly. Well on the 502 not so ! Only the tip of the screw is held in place. The head of the screw, where the red knob is, what yo interact with... is not secured/ guided at all, it's just flapping in the breeze !
Blew my mind.
Anyway, I soon would have bigger problems to deal with : when I worked that screw to align the CRT, it was not very responsive to say the least... had to turn it 20 times before it eventually, sliiiiightly, rotated the CRT. Something is wrong... So I looked at the clamp while I was working the screw, and the clamp DID move as it should... but the CRT was NOT !
Oh no !! The glue securing the plastic base to the neck/glass of the CRT must have dried and is starting to fail ?!
So that means the wires inside the base got twisted ! Luckily from memory, they are made of a very tough metal. Still, I bet they must be twisted / under stress in there, even if I can't see them... so they might fail one day, possibly.
Of course that means I can't adjust the rotation of the CRT. I did it by hand by trial and error, but it's a pain, time consuming and the result is not perfect, as you can see on the screen shot further down. So what can I do ?
Glue it back ? put a bead of super glue all around the base, where it meets the glass ? I need to restore the functionality... adjusting the rotation is just not viable without this mechanism.
Graticule illumination-tektronix-502-scope-repair-restoration/?action=dlattach;attach=2485777;image)
That didn't work, so I ordered x20 type 47 bulbs. Very common in the USA but rare in Europe. Had to import them from that random vintage audio German shop that Google found me.
While I was at it, I added a green filter to the scope, didn't come with one. Yeah I admit... as much as I love the blue phosphor, a filter improves the contrast and comfort quite a bit... ideally I would like to fit a blue filter, so that I can have the best of both worlds... I don't think these can be found easily never mind for cheap, so I guess I could make one myself with some tinted plexiglass or something ??
Then with some care, drill holes and makes cutouts for the light bulbs and the 4 studs.
Trace IntensityRemember before the wash, it was flickering very badly... Well up reassembly it still flickered, so I tapped the back of the intensity control pot on the front panel. Used the handle of a black "ESD safe" brush... and got zapped. Like, 3kV zapped... I didn't like it at all...
Will not make that mistake again... I nearly won a Darwin award...
Not flickering any more though !
Vertical amplifierThe lower beam was not showing on the CRT ! I feared it might due to wires inside the CRT base, that got twisted and broken maybe...
So in order to quickly figure that out, I measured the voltage straight at the deflection plates. If voltages are correct then CRT is toast. If not, the amplifier is kaput so there is hope, it can be fixed. Well, voltages were not correct at all. One plate was stuck at max voltage, the other was stuck at the lowest voltage. In short, the beam was there, but way off screen. So I spent 3 hours on the vertical amplifier, probing DC levels, and doing a lot of tube swapping experiments... Eventually narrowed it down to the pre-amp / first stage. I think there is a combination of weak tubes (a couple 6AU6), and some resistors must have drifted. It's not just the tubes I think. For, I replaced them with the two matching tubes from the working channel, and it did not fix the problem... but putting the tubes from the defective channel, into the good channel... did make the latter misbehave in the expected way. So the problem followed the tubes, but only in one direction so to speak.. so it's a bit weird, hence why I think the bad channel must have more than tube problems... so drifted resistors are probably at play here. Anyway, after some trial and error, using tubes from other scopes and some from my tub drawer... I eventually, by chance, after a while, just as I was about to give up and call it a day... managed to find a combination of tubes that worked well. Now when the vertical position control is centred, so is the trace on the screen. Miracle.
To be honest I am tired of this 6AU6 "fun"... it's a recurrent problem in these scopes. They are all over the amplifiers and create gain and offset issues. I have lots of scopes hence lots of 6AU6 but of course they are all in various states of wear, so I basically I am swapping used 6AU6s with other 6AU6s, hoping it will fix the issue... trying lots of them, hoping for the best.... takes lots of time and you never know how long it will be until you find good (enough) tubes.
I am bored playing this game
I am not rich but I think I will try and buy a few NOS 6AU6, and label them as such (on the glass itself), so that I can never mix them with all the other 6AU6 coming from scopes. I also want to take it a step further and be able to quantify the degree of tiredness of all these 6AU6 in my scopes, so that I am not working blind any more, and can diagnose things with more certainty and fix these scopes faster.. because I have a bunch of them to restore ! ... and I can't afford to spend then nest 10 years doing so... have many other things to do than just restoring these scopes...
So I am thinking of getting a tube tester so I can measure gain/emission. I don't fancy old tube testers are they are so crude and large and large and mega expensive here. The idea is use my Tek 575 transistor curve tracer with some adaption, so it can test tubes.
This way I get more than just a needle dancing on a vintage tube tester, but an actual curve I can compare to a NOS tube and the 6AU6 datasheet. Yes... that's what I want to do. So I will soon resume work on my pair of 575 tracers...I think.
ConclusionAnyway, that scope is pretty much done, cleaned inside out, put back together, and fixed / working. There is still more work I could do to it of course, and might do later, but it's now basically back to life and working. Remember the idea was to get this one working, enough, so that I can take measurements to help me fix the other 502 which has a no-trigger issue. So that's what we will do... go back to that other scope and make it work...
