Hello DaJMasta,
Glad to read that the TE is finally repaired.
As I mentionned in a former post, some design choices made by SR are a bit questionable.
It is also true that an old PCB tents to absorb humidity which favors leakage
Set the kitchen kiln to 50°C and 'bake' the board for 6 hours sometimes restores the isolation resistance between tracks.
You may also edit the title of this thread by adding the word that everyone wants to see in the repair section of the forum : '[SOLVED]'
