Note: I think I may type too much, will try to cut it down. Tried designing my pics in hopes of relaying more info with less paragraphs. Theyre also hi-res so can zoom in if needed. If theyre confusing/useless feel free to let me know.
Setting aside the scope until done checking voltages. With the unit powered on I checked all of the voltages on power supply board X00-1590-10.
Voltages listed below, main things that stand out are:
#14 &16: rapid changing mV from approx -23mV to +12mV. Also #17 & 19: I believe B- B+ are possibly incorrect.
![[Novice Project] Kenwood KR-9940: '70s TOTL Quad Stereo Receiver 848606-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=212226.0;attach=848608;image)
1: 50v... 56V
2. GND
3: 14V... 15.4V
4: 24V... 23V
5. GND
6. 10V... 9V
7. 10v... 9V
8. gnd
9. 24v... 23.7V
10. 14v.... 15.3V
11.gnd
12. 40v... 51.5V
13. 30v... 35.9V
(?) 14. UNSTABLE, rapid fluctuation +3mV to -16mV
15. GND
(?) 16. UNSTABLE rapid fluctuation ~+20mV to -28.3 mV
17. +b... 10.8V
18. gnd
19. -b... 11.3V
I also inspected the board, the transistors mounted to small heatsinks all measured at 60-70°C after idling for 20min minutes.
![[Novice Project] Kenwood KR-9940: '70s TOTL Quad Stereo Receiver 848610-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=212226.0;attach=848612;image)
There was a bit of a dark area and what appears to be a slightly yellowed resistor and some smaller resistors covered by cooked brown glue. It looks pretty bad but there is no corrosion and all of the resistors measure the proper resistance.
![[Novice Project] Kenwood KR-9940: '70s TOTL Quad Stereo Receiver 848614-2](https://www.eevblog.com/forum/index.php?action=dlattach;topic=212226.0;attach=848616;image)
I checked the small Protection & PS board, it's heatsinked transistor measured at 60°C after idling 20min. There was some browning of the board by Q1 but no other visual clues.
![[Novice Project] Kenwood KR-9940: '70s TOTL Quad Stereo Receiver 848618-3](https://www.eevblog.com/forum/index.php?action=dlattach;topic=212226.0;attach=848620;image)
![[Novice Project] Kenwood KR-9940: '70s TOTL Quad Stereo Receiver 848630-4](https://www.eevblog.com/forum/index.php?action=dlattach;topic=212226.0;attach=848632;image)
I believe I have gathered all of the numbers I need in order to continue troubleshooting. Now I need to do some research to find out exactly what to do with that data. Will update.
Any advice or critiques always appreciated.
