Not in my experience.
if you're suspicious, do an electrical test when you're done: verify that the capacitors are the correct value and not shorted. This may not be possible for all capacitors in a finished circuit, or maybe you can test as you go, I don't know.
Hmm, I wonder if the flex-contact type capacitors degrade with heat. AFAIK, they use an epoxy undercoat, which would be prone to decomposition at that temperature. (If the parts you bought don't specify flex type, then they're not flex, just plain old solid ceramic and metal.)
