Hey,
I am trying to fix a small angler grinder.
I tried to get the OEM part for the switch could not find it (4terminals/2poles Normal Closed, way off center switch).
Photos will be provided in the next post.
No ground wire is provided and I am not sure why.
I found a potential workaround that is to used those kind of microswitch.
I found a 10 (3) A 250VAC seller from germany on ebay.
Here is the listing:
https://www.ebay.fr/itm/323907219752I got some with small lever, small lever with "wheel".
I tried two alongside of each other. But it barely working but it would be really handy if I can use only one.
(I can adapt it with plastic PCL since this is an air intake the temperature is most likely not going above 62°C anyway).
It is safe to only use one pole switch on a small angle grinder ?
Or 2 poles switch are meant to avoid giving shock to the user if something goes wrong during grinding ?
Thanks you.
