Hello all,
The PSU was running when a lightning bolt struck far away. turned off and cannot power on again.
so probably overvoltage exposed.
I opened the PSU to replace the fuse. it is a ceramic one, there I cannot see on first sight if it is blown. Also removal seems unnecessarily difficult as it is soldered and no holders that may clamp it.
Did a sight inspection and did not see anything apparent.
As i do not have good soldering equipment, do you recommend to bring it to technician to solder replace the T10A fuse?
What else maybe to check before that?
with best regards
Hans
