Author Topic: Is my resistor damaged?  (Read 2939 times)
Offline nmooreTopic starter
« on: January 30, 2024, 03:23:51 pm »
Can someone please assist in telling me if my 20Mohm resistor is damaged? My circuit isn't working as it should but I noticed the resistor I-V curve looks weird on the component tester of my oscilloscope (see attachment)
Offline Haenk
Re: Is my resistor damaged?
« Reply #1 on: January 30, 2024, 03:57:03 pm »
You did not curve trace it in circuit, did you?
« Reply #2 on: January 31, 2024, 01:45:50 pm »
No I did not.
Offline RoGeorge
« Reply #3 on: January 31, 2024, 04:09:22 pm »
Does the "flat-line then slope" changes into a "slope then flat-line" when the resistor is reversed in the curve tracer?
- If not, I would suspect a malfunction in the curve tracer.
- If yes, then the resistor indeed behaves differently with the voltage polarity, almost like a diode.
I've read some oxide to metal contacts can act as a diode junction, so a high value resistor acting as a diode might be plausible.  :-//
« Reply #4 on: January 31, 2024, 06:29:09 pm »
When I reverse the resistor the flat line does change. Thank you for your reply
