The ic is something like AL8805. The pinout matches, but the marking code is slightly different (xxA6). There are many similar ic, operating the same way, so the exact type doesn't care.
It sounds like the ic is not operating. You can check the voltage at pin 3 if it is not shorted to GND and measure the voltage between 5+4 (current sense). If both are ok, the ic is dead.
