Author Topic: Acer AL1916 PSU Repair.  (Read 5894 times)
Offline B3nny11Topic starter
« on: January 26, 2015, 10:57:43 pm »
Soo, i am quite curious if the psu for this LCD could be repaired. Take a look at the pictures what is going on.
At first a thought that a cap blew. But that's not the problem I think. All the caps look good.
Any suggestions?
Thanks up in advance.
Ben
Edit: Yes when I plug the monitor in a wall socket it gives no life at all.
Edit2: The serial for the board is: 715G1492-2
Is there a easy way to test the caps? Perhaps with a multimeter?
« Last Edit: January 26, 2015, 11:45:06 pm by B3nny11 »
Offline Phaedrus
Re: Acer AL1916 PSU Repair.
« Reply #1 on: January 26, 2015, 11:47:02 pm »
I used to have an AL1916. Decent monitor.
What are the failure symptoms? It's quite possible that the power supply caps have failed without visibly bulging/leaking. Replace them all. Also, get some 90% isopropyl and clean all that dust off.
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
« Reply #2 on: January 27, 2015, 12:30:17 am »
Welp. No idea as said in the edited post, it just wont turn on.
The caps, is there a simple way to test them somehow? None of them have visible damage.
Fuse is ok. Cleaned the dust (most of it) with compressed air.
Offline Phaedrus
« Reply #3 on: January 27, 2015, 12:35:05 am »
An ESR meter. Low-ESR PSU filter caps should have 0.1-0.3mOhms ESR, if they read >0.6mOhms they're probably bad.
But caps are cheap. Should be able to get Panasonic/Rubycon/NCC replacements for less than $5; there aren't that many on there. Make sure to get ones with a good ripple current rating and 105C temperature rating.
- Albert Einstein
Offline Rasz
    • My random blog.
« Reply #4 on: January 27, 2015, 09:38:56 am »
no life at all = start with fuse, measure all semiconductors (mosfets, diodes) for shorts
Offline wraper
  • Country: lv
« Reply #5 on: January 27, 2015, 01:02:46 pm »
Did you measure the voltages on the output BTW. Nothing at all?
Check if there is voltage on the big capacitor when connected to the mains. If there is check another things on the picture.
« Reply #6 on: January 27, 2015, 10:37:44 pm »
Ou key, will do. Had no time today for it.
Will keep you posted.
Offline DmitryL
« Reply #7 on: January 27, 2015, 11:26:05 pm »
Any suggestions?
at first glance capacitirs look ok. Difficult to say without measuring their ESR. It was already suggested that you may need to check if PSU woks at all.
Another possible reason: degraded CCFL backlight lamps. Backlight invertor can't deal with it and shutdowns PSU. You can try disconnecting CCFL lamps connectors and see if PSU starts. If PSU works then, you can use external light source (flashlight for example) to shed some light onto the screen and see if there is a picture. It is very difficult to see it without backlight.
... replacing CCFL lamps in display module is a torture :)
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #8 on: January 28, 2015, 03:43:23 pm »
Did you unhook the connector to the other board? So are you testing without a load?
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
Offline oldway
« Reply #9 on: January 28, 2015, 05:39:33 pm »
And do not forget to check if you have the main voltage at the input of the psu.
« Reply #10 on: January 28, 2015, 09:09:40 pm »
Haha very funny. Enjoy it while it lasts. :)
« Reply #11 on: January 28, 2015, 09:17:26 pm »
I did measure them a while ago.
The main cap voltage kept jumping... I have no profesoinal multimeter, but I did see numbers from 50to300v.
So i ordered new caps, all of them.
Offline oldway
« Reply #12 on: January 28, 2015, 10:46:26 pm »
Main power switch with bad contacts ? :-DD
Offline wraper
  • Country: lv
« Reply #13 on: January 28, 2015, 10:54:01 pm »
Probably big electrolytic capacitor dead. And multimeter readings jumps when psu tries to start.
« Reply #14 on: January 29, 2015, 12:20:20 am »
There is no mains switch. ~_~
