I have a 600w mercury soft start inverter,its input was more or less a dead short,on investigation i found 2 banks of 4 fets, one of these was shorted between all legs,i replaced it but its still poorly,the 4 fets on the same bank/side of the pcb get hot in seconds,on further investigation all there gates have a squarewave drive but the waveform is riding on top of a 5v so the top of the peak is 12v the bottom of the squarewave is 5v,the fets are hard on as soon as power is supplied to the inverter,the pwm controler is a tl594 ic,any ideas what to check?.
