I had a look, it's definitely a custom ASIC and if there are no old-new stock somewhere, you won't get them anymore.
I'm also pretty sure that what kills them is the Blitz control via that thyristor or flash-ready input, they could have avoided that shit by using one diode in series with the gate, but hey 20c less it's not that bad coupled with planned obsolescence. A Little piggy-back board with whatever PIC/STM that has an analogue input and a couple of bipolar tranzistors should do the trick.
At a first glance the functionality it's like that (please correct me where I'm wrong):
S1 is the Power-Switch.
S2 is the Picture-Trigger switch.
LED1 is the weird green dot marker on the film for their weird photo-printers.
LED2 is LowLight condition.
LED3 is Power-OK/Light-OK.
With VR1 one adjust the shutter pulse vs light intensity.
The MG thing is either the aperture control (proportional voltage to light intensity) or shutter speed control (proportional pulse duration to light intensity).
Most likely the shutter speed is determined by the film sensitivity and the aperture opening is controlled by this chip.
So when the board is powered on via S1, it starts measuring the light and dynamically setting the aperture opening, when S2 is pressed, it pulses the film marker led and depending on the light intensity it triggers the blitz or not, it could be that the second pin going to the blitz shoe it selects in between two lamps on their also weird blitz.
If you have some working camera on a tripod, a good calibrated exponometer (light intensity measuring device), some adjustable light sources, a room to be used as testing studio, a good DMM and eventually a simple scope, I think it takes 2-3 hours of testing to clearly determine how the chip works, 1 week to concept the best and cheapest way to replace the chip and then either do a small PCB piggyback instead of the chip or just put on some breadboard and wires.
See, simple
, now where should I send you my PayPal for this analysis
Cheers,
DC1MC
