Author Topic: 18W USB-C TS80 LCD backlight when out  (Read 1664 times)
Offline FranticKoalaTopic starter
« on: May 21, 2020, 09:50:15 pm »
On the recommendation from video #1114 and what my needs are I purchased a TS80 about a year ago I have used it multiple times a day almost every day since i got it. It has been wonderful! ;D
The problem came a couple months ago when the screen "backlight" when out. It was quite hard to read but still worked. Recently though the screen had got so dim that 90% of the time I am not sure if it is on or not.
I re-flowed the screen connector and most of the chips on the PCB. That did not fix the issue.
What I don't know now is if it is actually a screen issue or if it is something else. If it is the screen itself does anyone know where i can get a replacement (The screen model number is quite hard to read).
Thank you for any help. FK
Offline chriva
Re: 18W USB-C TS80 LCD backlight when out
« Reply #1 on: May 21, 2020, 10:06:46 pm »
They have an OLED display so unless it has power delivery issues, it'd need a new display :)
