http://ampwares.com/schematics/100W_Mast_Vol_SF_Twin_Rev.pdfI am a bit lost on this amp. I replaced the filter caps and installed new tubes. The amp plays and sounds good.
The Vibrato does not work. The two Vibrato channels themselfs work and the reverb works.
Plate voltages for V1,V2,V3,V4, and V6 are OK
V5 has high plate voltage on pin one, 423V and should be around 300V, pin 6 reads 380V and should be around 440V
Plate voltage on V7,V8,V9, and V10 all read 435V which is more or less normal
I set the bias to 40mv on V10 and checked V9 which read 39mv
Both V7, and V8 read only 10.8mvI can not find a bad cap or resistor in the vibrato circuit.
One other strange bit. Per the schematic there is a 10K and a 100K resistor in series on the 22uf filter caps. The 100K is actually a 2.2K (red red red silver) but the voltage at the cap is correct. Schematic not correct?? Should I change it to 100K. Part of the problem?
What could cause the low plate current on V7 and V8? Are the two conditions likely related...low plate/vibrato not working Where do I test next?
Thanks,
Billy
Edit: The 100K resistor is one watt but I only have a 120K 2Watt on hand.
