Author Topic: 1980s Sanyo RM 6400 Clock Radio  (Read 1474 times)
Offline jt154Topic starter
  • Country: sg
  • better at spoiling things than repairing them
« on: July 02, 2018, 10:07:33 am »
Hey guys, first time posting here. I’ve recently acquired a Sanyo RM 6400 Clock Radio from a flea market that needs repair.
Everything is working except for alarm 1. When alarm 1 is set to radio, the radio comes on as it should. However, when it is set to buzzer, the radio comes on and instead of the buzzer, a popping sound is emitted from the speaker when the volume for the radio is set on minimum.
When I first got the clock radio the buzzer worked, but after one week of storage it has miraculously died. I suspect the TMS3459BNL chip might be to blame, but I’m hoping the problem might be something less costly as the cheapest chip I could find costs more than what I paid for the clock
Would anyone have any schematics or manuals? I couldn’t find any online. Greatly appreciate any help.
much better at killing things than repairing
Offline envisionelec
Re: 1980s Sanyo RM 6400 Clock Radio
« Reply #1 on: July 02, 2018, 02:08:09 pm »
When I was young, I would test my repair skills on clock radios. I had one exhibit behavior that was very similar to this. I could never find the problem, but chalked it up to lightning damage - here's why: the FM-band antenna is usually coupled to the AC line cord. A high energy spike generated from a nearby lightning strike can easily induce a current into the antenna and convert to a massive energy pulse across the PCB and damage the microcontroller.
These were generally disposable items, even in the 1980's...
  • Country: sg
« Reply #2 on: July 02, 2018, 02:13:01 pm »
I desoldered all of the electrolytic caps to measure their values, seems like some are gonna need replacing. Hopefully that will fix the problem.
I have2 radio clocks, one of them is the Sanyo (which is my favorite), the other is a Philips D3200. The Philips units works fine except that someone cut off the antenna wire so I’ll have to solder a new length of wire for that and it should be fine.
