You will need to decide if the fault is on the power amplifier
side, perhaps bias idle current is to high after replacing blown
out components, and maybe you haven't found all of the bad
parts over in the audio amplifier section. What you really need
to know is the 'normal' pulse width of the switch mode power
supply at idle and see if your pulse width is much longer. If
the power transformer has a shorted turn that would cause
the pulse width to increase. Also if any of the bridge rectifiers
on the output side of the transformer are bad that could cause
extra loading or the regulated voltages to be way off also making
the duty cycle to long. You will surely need an isolation transformer
to do this testing. Since most of your troubleshooting will be at
low audio power, or even no audio output you can use a much
smaller iso transformer, perhaps 200va rated. I have over 25
years of SMPS skills repairing the Carver PM-2.0T 1 kilowatt
audio amps specifically built for Clair Brothers / ShowCo.
Tell us more as you continue to troubleshoot, we may be able
to offer additional ideas.
