Author Topic: Where can I get Triplett VOM model 1200-F data?  (Read 1053 times)
Offline basinstreetdesignTopic starter
« on: February 23, 2019, 07:45:00 pm »
I've finally taken a meter I've had for several years off the shelf to see if I could fix and calibrate it. I would like it to be just as good as new again.  :-DMM
It's a Triplett VOM model 1200-F in pretty good shape except for a lack of a battery box, a busted pin jack and a sticky push-button switch. I have Googled several times but can find nothing on this instrument. Does anybody know where I can get a schematic or specs on it?
Thanks in advance, Tim.
STAND BACK!  I'm going to try SCIENCE!
Offline barry14
Re: Where can I get Triplett VOM model 1200-F data?
« Reply #1 on: February 23, 2019, 09:18:02 pm »
Some information can be found at the following site:
https://www.radiomuseum.org/r/triplett_volt_ohm_milliammeter_1200f.html
