Hello Chris,
yes the store is growing, too bad it is always a different type or rated component that say goodbye.
After I came on-board the El-workshop looks more and more like a electronic service shop than the old boring change of el-motor bearing setup.
It's to bad that the "not working throw away" mentality normally rules.
This one converter cost 5800 EUR and they have changed 2-3 of them previously, and as far as I can see the culprit on all of them is ONE ceramic capacitor fail... less than 1 EUR in spare parts
On the other converter with same problem there is another channel that is faulty, but I have not been able to take it out and check yet. If it is the same capacitor, but on different phase. I will have to change all of them to be sure it will be a lasting repair.
I did not notice your comment about the pinout on the diode, but it's correct. There is a total of 6 DC-DC supplies on the card one for each 1/2 period on each phase. so I had a few to compare to. The temporary fix gives identical total power draw compared to the others so I am pretty confident this will solve the problem.
I just wish I had better tools for this sort of repairs. I only got a generic temp controlled iron and a fluke... lol, that makes varnish covered SMD electronic repair a bit of a hassle. Don't even got solder wick! but it is on the way already
We sailed from Great Yarmouth few days ago, and now we are east of Leeds at Hornsea field.
Again thank you and enjoy the weekend.
Kim-Andre
