Author Topic: 1st time Deoxit D5 user. Is the Windex smell normal?  (Read 1488 times)
Offline Cliff MatthewsTopic starter
    • General Repair and Support
« on: June 07, 2019, 04:48:47 pm »
Bought it locally this morning (@ $25 CAD ~18 USD it was priced better than Amazon.ca) could this be a fake?
Not only the smell caught me off guard, the over-label did too (turned-out it's a just a bilingual Canadian thing..)
« Last Edit: June 07, 2019, 05:49:10 pm by Cliff Matthews »
Offline Bill158
Re: 1st time Deoxit D5 user. Is the Windex smell normal?
« Reply #1 on: June 07, 2019, 07:55:27 pm »
I get a smell more like a weak RAID or pesticide, but it could be a windex smell also.
Is the liquid a weak Red in color?
Bill
« Reply #2 on: June 07, 2019, 11:20:29 pm »
Well, if you mean weak red, as in red-shift in stars, I think so. I sprayed it on some paper and it's so fine it soaked fast through instantly onto a metal surface below. So I let both sit for a few hours. FWIW, I wanted to go slow since this will be sprayed into pots on a vintage TEK T935A scope. See what you think..
Offline amyk
« Reply #3 on: June 08, 2019, 01:19:02 am »
Certainly does not help that the MSDS lists the ingredients as "trade secret - proprietary" |O
The following users thanked this post: Cliff Matthews
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
Voltage does not flow, nor does voltage go.
« Reply #5 on: June 08, 2019, 12:01:12 pm »
You're right, I wasted $25 :palm: at the top of the 2nd page..
Offline Bud
« Reply #6 on: June 08, 2019, 12:21:27 pm »
 Where did you buy it ?
« Reply #7 on: June 08, 2019, 05:32:00 pm »
KW Surplus in Kitchener (https://goo.gl/maps/7VThNont2zrzT2RY7).
AFAIK, they just started carrying it, so if you're closer to the Cambridge or London stores, check them first.
