My Marconi Signal Generator 2024 has a bad power switch. Otherwise it works fine.
How can I replace the power switch with same or add an external one if replacement is not available.
I searched the site and found no help, repair companies do not want to do this repair.
--> I can use schematic to replace with an external switch, it has four cables going to it.
Thank you for any ideas. wd6y@arrl.net
