Author Topic: 5333h 1xha - CPS533 Voltage Regulator Info or Substitute  (Read 763 times)
Offline Hundleton1Topic starter
  • Also known as Ian
« on: September 27, 2022, 09:53:02 am »
Hi everyone, I hope it’s ok to post this here, if not I apologise and please tell me where would be best :).
I am trying to find any info on a voltage regulator that’s labelled 5333h 1xha that we believe is a CPS533 5v regulator.
I can find nothing on this part at all. Not even a data sheet.
If anyone has any data sheets, info on supply or an alternative I and the FPV community would massively appreciate it .
A little bit Mad here and there.
Offline fzabkar
Re: 5333h 1xha - CPS533 Voltage Regulator Info or Substitute
« Reply #1 on: September 27, 2022, 07:49:16 pm »
I found a reference to CPS5333 in this teardown:
https://view.inews.qq.com/k/20201019A02MJH00?web_channel=wap&openApp=false
The part marking is 5333, not 5333H.
There is also a CPS8100GQ part in the same teardown. Its logo belongs to Convenient Power Semiconductor, also known as Convenient Power Systems.
Their web site is basically useless:
https://convenientpower.com/home/
I did find a totally unrelated datasheet which confirms the identity of the company and logo:
https://edit.wpgdadawant.com/uploads/news_file/program/2022/36980/tech_files/program_36980_suggest_other_file.pdf
Here is another reference to a CPS5333 buck converter:
http://www.icsmart.cn/53387/
Edit:
I'm getting closer:
https://convenientpower.com/home/power-management/ (CPS5303/5/7)
« Last Edit: September 27, 2022, 08:14:04 pm by fzabkar »
