Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
240v UVC lamp
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 240v UVC lamp (Read 869 times)
GadgetBoy
Regular Contributor
Country:
240v UVC lamp
on:
September 24, 2020, 11:16:04 pm »
So, bought this thing on eBay, seller didn't mention that it was a 240v bulb... Is there an easy way to change the components on this to make it function on 120v?
Logged
TheMG
Frequent Contributor
Country:
Re: 240v UVC lamp
Reply #1 on:
September 25, 2020, 01:56:27 am »
Add a capacitor and use the bridge rectifier as a voltage doubler like what was commonly done in computer power supplies with the voltage selector switch.
Logged
GadgetBoy
Regular Contributor
Country:
Re: 240v UVC lamp
Reply #2 on:
September 25, 2020, 02:02:11 am »
I think I know what you mean. Add the cap in the "middle" of the rectifier?
Logged
james_s
Super Contributor
Country:
Re: 240v UVC lamp
Reply #3 on:
September 25, 2020, 02:45:56 am »
Reconfigure the input as a voltage doubler.
The usual configuration is a full wave doubler, it looks like a bridge rectifier except it uses two diodes and two capacitors instead of four diodes.
https://electricalacademia.com/electronics/half-wave-full-wave-voltage-doubler-working-circuit-diagram/
You might also find that it works fine on 120V perhaps at slightly lower than rated brightness. I have some 240V CFLs from England and I was surprised to find they work fine on 120V although I don't know if that would be detrimental to their lifespan.
Logged
GadgetBoy
Regular Contributor
Country:
Re: 240v UVC lamp
Reply #4 on:
September 25, 2020, 02:50:51 am »
It does not function on 120 (it's a quartz UVC lamp), so I'm hoping to get it working.
From what everyone is saying, it looks like my original plan of putting a single stage WC on the mains input should do the trick.
Logged
GadgetBoy
Regular Contributor
Country:
Re: 240v UVC lamp
Reply #5 on:
September 25, 2020, 07:01:15 pm »
Found this, which confirms the mental idea I was forming of how to set this up.
Logged
james_s
Super Contributor
Country:
Re: 240v UVC lamp
Reply #6 on:
September 25, 2020, 07:15:28 pm »
That will work, but it is more complicated than it needs to be. Notice that each of those capacitors is actually in parallel with D3 and D4, so those two diodes can be eliminated and replaced with the capacitors.
Logged
GadgetBoy
Regular Contributor
Country:
Re: 240v UVC lamp
Reply #7 on:
September 25, 2020, 07:31:30 pm »
Last question, do the caps have to be polarized as indicated in the diagram?
Logged
Gyro
Super Contributor
Country:
Re: 240v UVC lamp
Reply #8 on:
September 25, 2020, 07:42:26 pm »
No, they don't have to be, it's just a matter of getting a large capacitance in a small space (electrolytics). The polarities shown are the ones you
must
use if they are polarized, to avoid reverse biasing them.
Last Edit: September 25, 2020, 07:45:09 pm by Gyro
Logged
Best Regards, Chris
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
240v UVC lamp
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
