What about the other voltages, are they also high with the 4ohm load on +5VD? Is it possible to show both primary and secondary side of your PSU and lastly, did you use low ESR caps?
I bought mostly Nichicon KL series, that's about what I could find at the moment. KL caps are advertised as having Low Leakage current, but there's no mention of impedance.
I have attached a page of the A2 and A3 board. I am testing the PSU only with all the connectors detached. An isolation transformer is used. With 110VAC output, and shorted J206 and J207 on A2 PCB for 115V input.
With P231 unplugged, voltage across Pin 1 and Pin3, is +55V, Pin2 and pin3 is -55V, which makes sense.
But with P231 plugged in, Pin1 and Pin2 voltage is almost 160V and -160V respectively.
Also, on the schematic where it says +264V* (on T1020 pin1), the actual voltage is measured to almost 350V (across R1020 and R1064 REF). Could a short circuit somewhere causing it?
I double triple checked all the caps on inverter and regulator board, i didn't find any caps that are reversed.
Did you check against the silkscreen or the schematic? I think i remember seeing a silk screen error for one of the caps (reversed)... But i'm not sure now and i also recapped a number of scopes at that time. Only one of them being a 2465.
I checked the polarity against silkscreen, but when I was recapping them, I matched the original cap polarity.
