Also, many solder joints were cracked - and that alone took quite some time to inspect and reflow.
It was a little dirty and had some mild corrosion on some other DIP-14 ICs. Nothing too serious but needed the vinegar+soap wash combo.
Everything came out spic and span.
The jump wire was soldered to the wrong leads:
the seller made a R5 to pin11 of a MC74HC14AN (
https://pdf1.alldatasheet.com/datasheet-pdf/view/164836/MOTOROLA/MC74HC14AN.html),
that in turn connects to pin 13 of a SN7406N Datasheet (
https://pdf1.alldatasheet.com/datasheet-pdf/view/27354/TI/SN7406N.html);when in fact it was connected to R6.
-- my guess is that he followed the wrong trace and on the wrong assumption that is wasn't making contact he wired it.
I hope nothing happened there.
Traces:
some were actually good on continuity test, but when I scratched away the old solder mask a couple came off in bits;
another one was gone;
two others had indents of corrosion.
I tinned everything and restored the dead traces. Nothing fancy, it was easy.
Socketed chips:
- BIOS chips were so oxidised that my TL-866 struggled to read them indicating bad contact. Cleaned and perfect reads and writes.
- Keyboard BIOS, same, heavily oxidised. Cleaned and I hope good to go.
Sockets deoxidised thoroughly, let's hope it's good too.
I had to replace a cap that had a broken leg (it came straight out) (C63 pic), removed a broken 10K resistor (replaced with a smaller size - see R4).
Yesterday I was too tired to fire it up and watch it fail - LOL
Later today I'll test it.
