Author Topic: 2SB1019 Transistor Replacement  (Read 729 times)
Offline spongellaTopic starter
« on: April 21, 2020, 09:01:07 pm »
Hello all, I have just aligned an Icom 28A that was bought used, all is fine except the output on hi is 20W, specs say 25W.  Was thinking that the final transistor might be soft  so does anyone know a place to buy a single 2SB1019 transistor other than EBay?  I prefer a vendor in the US if possible.  Thanks and 73's.
« Last Edit: April 22, 2020, 09:34:54 am by spongella »
Offline coromonadalix
Re: 2SB1019 Transistor Replacement
« Reply #1 on: April 21, 2020, 09:52:43 pm »
this page could help you      i think you meant 2sb1019  ???   q17 transistor ?
https://vetco.net/products/nte378-pnp-transistor-si-power-driver-power-output
It list many transistors numbers ...  and the equivalent in nte part
« Last Edit: April 22, 2020, 06:31:58 am by coromonadalix »
Offline picburner
« Reply #2 on: April 22, 2020, 04:33:21 am »
If you are referring to IC6 it isn't a transistor but a hybrid module, a SC-1019, and you can find it here
The following users thanked this post: spongella
« Reply #3 on: April 22, 2020, 06:34:48 am »
Apparently this one is an equivalent ??
https://www.rfparts.com/sav7.html
and
https://www.aliexpress.com/i/32329894636.html
for a cheaper price ??  maybe a clone or fake ??
« Reply #4 on: April 22, 2020, 09:33:37 am »
Pardon the typo, yes it is a 2SB1019.
 Didn't cross my mind that it could also be the power module.  Thank you all for the responses, they were very helpful.
« Last Edit: April 22, 2020, 09:42:46 am by spongella »
Offline andy3055
