Also consider disconnecting the output (cut traces if necessary..?) and adding a dummy load. The hazard is then limited to PSU components, or maybe at worst, fusing some traces (but the fuse should be rated enough to avoid that already).
These kinds of circuits don't blow up the output; if switching stalls, there's simply no flyback and thus power output. Which is true even if the device fails shorted, dumping the filter caps + mains fault current into the transformer.
There can be a runaway effect when the feedback (drive) voltage exceeds Vebo, returning bias current to the base circuit that's otherwise meant to be managed by the feedback circuit, hastening turn-on for the next pulse; the maximum output is still limited by transistor rating and transformer saturation, so a shunt regulator or crowbar can handle this just fine. (In particular, a crowbar also (nearly) shorts out the transformer, forcing it back into a startup condition.) Anyway, Vebo is usually pretty generous (have seen/measured 10-12V on HV BJTs before I think?) and never less than, well, whatever it says of course (7V in present cases). So, if it works in the first place, this effect won't show up with whatever else; that is to say, it's a design issue more than a component selection issue.
