The question is what for? If they measure like diodes (in one direction), they're likely fine regardless of what they actually are. Then you could measure voltage on them in working circuit. I rarely bother wasting time on figuring out model/value of random components unlike many inexperienced repairers here. I only do so I suspect there is something wrong in particular part of circuit. If they seem fine on a first glance, I'd be looking somewhere else for issues and return back if did not find any suspects instead of trying figure out a model of every single component.
