Author Topic: 2sd323 transistor information  (Read 1349 times)
Offline innkeeperTopic starter
« on: December 20, 2019, 07:21:43 pm »
I am looking for the data sheet for a 2sd323
been searching all the internet resources and can only find basic electrical characteristics, and, they really don't agree with each other and none are official data sheets
I know NEC made them and I have some labeled sony, not sure if sony made them or maybe NEC made them for Sony.
I'm particularly interested in the HFE vs Current graph .. thanks for any help :)
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: 2sd323 transistor information
« Reply #1 on: December 21, 2019, 01:37:18 am »
Also could be BD323, often the B is left off.  That would be a TO-39 instead of a TO-3.
Why do you need the hFE(Ic) curve specifically?
Seven Transistor Labs, LLC
« Reply #2 on: December 21, 2019, 05:32:40 am »
I'm looking at an old amplifier design.  looking to see if the transistor used caused any significant compression.
its typical for lower hfe at higher currents but where it starts to drop and by how much makes a big difference.
i learn a lot from seeing what engineers had in mind as they designed things.
i'm trying to avoid needing to characterizing the transistor to find out.
i'll search for a bd323 too.. see if i come up with anything
« Reply #3 on: December 21, 2019, 05:41:42 am »
found the bd323 spec... it's definaly not a bd323 which is a 1a ic
its a TO-3 @ 7A IC
Offline magic
« Reply #4 on: December 21, 2019, 12:19:18 pm »
Maybe you would have luck finding complete databook of the manufacturer from appropriate year. Some people scan and upload those things.
« Reply #5 on: December 21, 2019, 05:00:14 pm »
i've started down that road, hoping to find a manual scan or hard copy. So far no luck, though they have to exists.
think a lot of them were in Japanese at the time. this is circa 1973. id be happy to find one even in Japanese.
Offline fastguido
« Reply #6 on: December 22, 2019, 10:51:54 pm »
I have some specs that are listed in my 1988 Japanese transistor manual, but there is no graphs.
« Reply #7 on: December 23, 2019, 07:33:57 pm »
not sure if its the same info
here is a Japanese data manual Fromm 1981 i found
if it is any different please post, thanks
Offline Pete66
« Reply #8 on: December 23, 2019, 07:58:21 pm »
Here you can find datasheet and a cross reference
https://alltransistors.com/transistor.php?transistor=19385
Offline fastguido
« Reply #9 on: December 23, 2019, 09:31:07 pm »
Looks the same.
« Reply #10 on: December 26, 2019, 03:49:53 am »
hi Pete, I did see that one, unfortunately, none of the pdf's they link to are for the 2sd323 and half of text-based specs do not agree with the Japanese sheet.
thanks though, I appreciate you pointing it out.
I may have to blow the dust off the curve tracer.
