If it's for a Dyson it's probably a custom part. A lot of universal motors like that are made by Lamb and you might be able to find something similar but it may be tricky to get an exact fit. You'll also want to figure out why it burned out, that sort of failure is rare, did the airflow used for cooling get clogged?
Another option that may be possible is rewinding.
