Author Topic: Ps-305d power supply  (Read 1218 times)
Offline Abdulla544Topic starter
  • Country: iq
« on: May 26, 2021, 09:45:11 am »
Hi
My ps-305d 30v 5A power supply '' FINE'' range didn't work properly so I opened it up and I just figured out that it was a 1k dual-line pot that u can adjust the voltage at about 0 to 2.5v the button of it didn't work I didn't have 1k dual-line pot instead I attach 50k then my power supply showed short-circuit on the output display nothing wrong happened like smoke or something but I no longer have the ability to control the voltage I just can control the amp section and by the way, the output polarity protection diode didn't short and I also tested the output ohmage it showed 850ohm not short-circuited.
Can u please help me how to fix it?
Offline BreakingOhmsLaw
  • Certified solder fume addict
Re: Ps-305d power supply
« Reply #1 on: May 26, 2021, 10:17:27 am »
You already answered your own question.
The fine adjustment is a potentiometer that is in series with the coarse adjustment. You replaced that with a 50k instead of 1k, so that can't work.
Replace the 50k pot with two fixed 470 Ohm resistors from wiper contact to upper/lower pin and see if the coarse adjustment works again.
Offline aa0cn
    • AA0CN RADIO PAGE
« Reply #2 on: June 22, 2021, 07:14:25 pm »
I did a finals repair on my PS-305D, so not the same issue, but you can find schematics for this unit here: https://aa0cn.neocities.org/ps-305dm.html
Or from PierAsia on his site here: https://www.pieraisa.it/php/myHwProjects.html
Hope this is helpful!
« Last Edit: June 22, 2021, 08:51:56 pm by aa0cn »
