Check you are getting "clean" DC to the backlight inverter.
Indentify the inverter controller IC and get the datasheet.
Some inverters have Over Current shutdown protection, disabling it is a common fix, recommended?
Inverter operation can be confirmed just with a scope probe used like a "near field" probe. (no connection)
That should get you started.
