Author Topic: HP/Agilent/Keysight 34401A 2W Ohm strange phenomenon  (Read 5862 times)
Offline coldframeTopic starter
  • Country: kr
  • Math isn't lie.
« on: September 20, 2014, 09:43:14 am »
Hello Forum.
I already fixed previously
https://www.eevblog.com/forum/testgear/34401a-cal-error-707/
Thanks again Dr. Frank, free_electron, robrenz :-+
New problems seem to come thick and fast  :palm:
I would like to do Fix this problem before Calibration Request
Symtoms
0. Self Test Pass.
1. Power on, 2W Mode button Press, OVLD OHM is Normal Display (Attached Photo : pic2)
2. Touch my finger  Hi Input Jack, "1xx M OHM" Dislay (Attached Photo : pic3)
    or, Power on, after a 2~3 minute lapse "1xx M OHM" Dislay (Attached Photo : pic4)  * bottom unit
3. Known good meter (Attached Photo : pic5)
   * upper unit
Add:
4. Ohm OFFSET Error 722 (Cal 2-wire ohms function offset out of range)
   - Short front Input Jack then  CAL-> CALIBRATE -> OHM 2,3,4 Beep
    * I am speculating phenomenon as the reason.
* Other function normal
In my experience,  Agilent/Keysight do not  repair, only Change Mainboard
understand that, but It's too expensive, too harsh
How can I understand This situation?.
Please share  knowledge
Thank You!~
Reference. (an excellent article)
https://www.eevblog.com/forum/repair/hp-34401a-drift-in-the-2w-r-mode-in-the-100-ohm-range/
Thank you Z, for sharing your knowledge
« Last Edit: September 24, 2014, 04:19:24 pm by coldframe »
  • Country: kr
  • Math isn't lie.
Re: HP/Agilent/Keysight 34401A 2W Ohm strange phenomenon
« Reply #1 on: September 26, 2014, 12:32:06 pm »
My Unit  Serial is 3145Axxxx Rev B
I found great post,
https://www.eevblog.com/forum/repair/hp-34401a-error-612-613-615-617-618-619-621/
 I Checked but  looking a bit strange  U201-B Pin 6,7 Voltage
Blue : Zucca,  Green : Dr. Frank, Red : Mine
How can I understand This Situation?
I would really appreciate any help.
« Last Edit: September 27, 2014, 09:47:25 am by coldframe »
  • Country: kr
  • Math isn't lie.
« Reply #2 on: September 28, 2014, 06:54:53 am »
Here below the  some measure (Measured with a Fluke 189)
Patient Meter,
The DC current during 2W Ohm measurement
0.63 uA in 100 M range
0.63 uA in 10 M range
5.11uA in 1 M range
10.07 uA in 100 k range
100 uA in 10 k range
0.998 mA in 1 k range
0.998 mA in 100 Ohm range
Thanks Again, Highvoltage
The DC Voltage during 2W Ohm measurement
2.6154V in 100 M range
4.7315V in 10 M range (unstable,  increase slowly)
6.202 in 1 M range
6.676V in 100 k range
7.726V  in 10 k range
7.244V in 1 k range
7.244V in 100 Ohm range
known  good meter
0.59 uA in 100 M range
0.59 uA in 10 M range
5.15uA in 1 M range
10.24 uA in 100 k range
101.1 uA in 10 k range
1.008 mA in 1 k range
1.009 mA in 100 Ohm range
2.6533 in 100 M range
5.078V in 10 M range
7.318V in 1 M range
7.312V in 100 k range
7.230V in 10 k range
6.808V in 1 k range
6.808V in 100 Ohm range
Offline Rick
  • Country: tr
« Reply #3 on: September 29, 2014, 06:56:58 pm »
I have the same problem on one of my HP 3457a's.
But the change is immediate. When I blow in the jacks I have the same effect. This affects the measurements.
Offline SArepairman
  • wannabee bit hunter
« Reply #4 on: September 30, 2014, 08:50:32 pm »
blowing on high impedance things seems to cause noise, are you sure one of the meter is not set to <10Gohm? play with an electrometer some time, it is fascinating, rubbing your hair 10 feet away causes readings.
but my 34401a is not sensitive to this
« Last Edit: September 30, 2014, 08:58:23 pm by SArepairman »
  • Country: kr
  • Math isn't lie.
« Reply #5 on: October 01, 2014, 08:04:14 am »
hello Rick,SArepairman
Yes the multimeter’s input resistance is 10M Ohm(default)
I’ve read the Service manual, Artcle, but I’m still none the wiser.
Display OVR.D  OHM, When I touch my finger in the vicinity of Q203  (Attatched Photo, Green Cricle)
Is is definitely not normal.
Well, I have a day job
when not crowded with work, They are both currently being investigated
Anyway, I appreciate your interest.  :)
Regards.
« Last Edit: October 01, 2014, 08:19:53 am by coldframe »
Offline Rick
  • Country: tr
« Reply #6 on: October 01, 2014, 10:31:11 pm »
Regards.
I did not mean to hijack your thread, sorry.
Just to clarify:
@SArepairman: the same behaviour is observed when nothing is connected to the inputs and I do not blow, but I simply touch the jacks or I do not, with 10 Gohm input impedance (I think it is 10Gohm).
Offline motocoder
  • Electrical Engineer
« Reply #7 on: October 02, 2014, 02:12:03 am »
I just tried setting mine to 10G input resistance, but it does not exhibit this behavior.
Offline Zucca
  • EE meid in Itali
« Reply #8 on: December 20, 2014, 01:38:36 pm »
Just jumping on this without thinking too much, sorry if I overlooked something....
Did you had a short between + and - post so the display was 0R and then OVR?
Is the problem reproducible when you tap the same spot with an isolated object like a plastic pen? If yes try to reflow the components there.
