Author Topic: 34401A Replacement Transformer  (Read 1309 times)
Offline CrazyTigerTopic starter
  • Country: my
« on: April 11, 2022, 03:15:13 am »
I have two 34401A with defective transformer, someone tried injecting 240V to the meters set at 110V. Now looking for replacement, keysight no longer sells them, with details as link below:
https://www.keysight.com/my/partDetail/34401-87901
Best part they are selling eeprom and smd resistors, capacitors and whatnot which requires soldering, but a simple user replaceable transformer requires keysight expertise for replacement.
Anyway I found lots of China made equivalent transformers on Ebay, has anyone tried them?
Another keysight joke, fuse requires keysight expertise as well  :P
https://www.keysight.com/my/partDetail/2110-0780
Thank You
Offline floobydust
Re: 34401A Replacement Transformer
« Reply #1 on: April 11, 2022, 04:13:35 am »
How far did the roasting of the transformer go? It might have a thermal fuse that popped (on the common/neutral leg) and worth a dig to replace it. If there is continuity between primary to the electrostatic shield, then I'm afraid it's dead Jim.
Search for the original part number Tranex 9100-4972 is better, but I also see listed for the 34401A Tranex 9100-5608 but is for 34970A I believe.
Offline coromonadalix
« Reply #2 on: April 11, 2022, 10:43:34 am »
some transformers can be found on fleabay   some are originals some are clones  of the originals    normally in the 70-80$ usd range   ???
But for mine i had the chance to buy an original
The only test you could do, is buy one and test the output voltages if they are in the needed range / values ?? on ebay you will have some warranty or a possible claim if they are not correct ?
« Last Edit: April 11, 2022, 10:45:32 am by coromonadalix »
Offline HighVoltage
« Reply #3 on: April 11, 2022, 11:39:08 am »
I would contact Keysight directly. Sometimes they have stock on items that are not listed officially.
Offline IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #4 on: April 11, 2022, 09:59:54 pm »
Keysight are pretty good at replying to parts enquiries......can take them a couple of weeks to reply though.
Ian.
Website: www.ianjohnston.com
Offline TaylorD93
« Reply #5 on: April 11, 2022, 11:29:46 pm »
I can understand the fuse.
If a fuse pops there usually (not always) a reason why, which may need investigating further. Not all companies are willing to just open up and repair their own instruments. So Keysight are obviously going to be on the side of caution and say "oh yes you need to send it back to us to give it a clean bill of health once we have replaced the fuse"
With the transformer itself, as Ian said, drop them an email. They've never not got back to me, just slow at times. They maybe able to do a surcharge/PX on your old transformer etc.
But as so many 34401A were built, id be very surprised if they have run out of spares that quickly.
  • Country: my
« Reply #6 on: April 14, 2022, 12:08:26 am »
Update:
I have done all the options suggested here.
1. Ordered 1 China made transformer, to see the performance
2. Dropped an email to Keysight, awaiting reply
3. Will be operating the defective transformer to see if the thermal fuse popped inside.
So hopefully in 2 weeks time, I can update how it went :)
