Author Topic: [solved] Need help with diode replacement  (Read 1893 times)
Offline RayRayTopic starter
« on: March 04, 2021, 01:54:05 pm »
Hey guys.
I need to replace a few fried diodes on an old amp (30DF2 ones) and I don't have an exact match in my stock, but do have a couple that could potentially suffice (MUR460 & UF5408) and this is what I need your help with.
Here are the datasheets:
Original (30DF2):
https://html.alldatasheet.com/html-pdf/86434/NIEC/30DF2/79/1/30DF2.html
Potential replacement #1 (MUR460):
https://www.onsemi.com/pdf/datasheet/mur420-d.pdf
Potential replacement #2 (UF5408):
https://www.vishay.com/docs/88756/uf5400.pdf
They seem to be compatible for the most part (with some small quirks). Is it okay to replace a fast diode (200NS) with a faster one (50/75NS)? Also, does it matter if the replacement is rated for a slightly higher "Maximum Instantaneous Forward Voltage" than the original? Looking at the datasheets, do you think these replacement optiosns are adquate? Thanks!
« Last Edit: March 04, 2021, 09:26:45 pm by RayRay »
Offline bob91343
Re: Need help with diode replacement
« Reply #1 on: March 04, 2021, 07:53:35 pm »
A circuit diagram would help.
The following users thanked this post: RayRay
Online fzabkar
« Reply #2 on: March 04, 2021, 08:28:43 pm »
I would use either as a substitute.
Offline floobydust
« Reply #3 on: March 04, 2021, 08:43:50 pm »
For the speed issue, need to see where they are used to know if it will affect things. Likely not at audio frequencies.
Higher voltage diodes can have higher forward voltage i.e. MUR320 (200PIV) 0.89V vs MUR330-360 (300-600PIV) 1.28V at 3A.
UF5402 is 200PIV 3A fast recovery 50nsec, Vf=0.9V 3A for the UF5400-5404, Vf=1.4V 3A for the UF5405-5408.
30DF2 is 200PIV 3A fast recovery 200nsec, C-16 case Vf=1.05V 3A
« Last Edit: March 04, 2021, 08:46:22 pm by floobydust »
« Reply #4 on: March 04, 2021, 09:19:33 pm »
Update: Ended up using a slightly lower UF diode (UF5404) and the amp works perfectly now!
Thanks guys.
