I'm trying to repair an old 5.245" floppy drive to work with my old Acorn BBC computer. There is a problem with the spindle motor where it sometimes requires a 'nudge' to get it going. Once spinning, the drive reads perfectly well.
You'll see from the first photo that I have put marks on the rotor (that match a mark on the chassis) at the positions where the motor requires a push to get started. I also took the rotor off and activated the motor to see if the stators were all magnetizing. The stators that have a mark on are the only ones that seem to get magnetized. I'm not sure if this is a problem though, as there are hall sensors under the rotor and I'm guessing that they inform the controller IC which field to turn on so it may be that with the rotor missing, no other fields are getting activated.
BTW, the dodgy jumper wire is something that I had to add as a capacitor had leaked and removing it from the PCB took off the pad.
Any idea what should I test for next in order to repair this?
Thanks
