Author Topic: PES51 repair - looking for a suitable glue  (Read 324 times)
Offline mazurov
« on: January 29, 2022, 12:52:18 am »
After 17 years my trusty soldering iron became loose in a typical place (see picture). I'm trying to find a glue that:
1. Heat-resistant to ~200C
2. Bonds well to Bakelite
3. Bonds well to steel
4. Available in the USA
Back in Russia I would use the product called БФ-2, it covers 1-3 but since it's flammable I'm not sure I can send it via mail. It's 98% PF resin, 2% PVB. Does anyone knows about similar product available in the states?
Thank you!
With sufficient thrust, pigs fly just fine - RFC1925
Online jdragoset
Offline pqass
Re: PES51 repair - looking for a suitable glue
« Reply #2 on: January 29, 2022, 01:26:10 am »
You could wedge a few strands (pulled from standed wire) between the handle and the metal, push the two together snuggly, then cut off the excess.
Offline jpanhalt
« Reply #3 on: January 29, 2022, 01:34:03 am »
Does this fit that description of PV (aka novolak) and PVB ( aka polyvinylbutyral ):  https://www.sbhpp.com/products-applications/catalog/item/fers-t840-40%3Fcategory_id=6.html
I am sure there are others.  Google "formaldehyde resin glues" may find something similar.  They were used widely in wood boat and aircraft
construction.
Edit: As for that repair, your application does not appear to require much strength.  Loctite/Henkel make a line ot adhesives that are sold to keep threaded fasteners from coming apart ("lock tight nuts").  Some are rated for high temperature.  I believe what we called the "green" version will work on engines that get quite hot.
« Last Edit: January 29, 2022, 01:40:21 am by jpanhalt »
