Thanks for the good advice. I did what you suggested. Found a slightly too small spring clip from a local electronics store that I could adapt. Temperature seems much better. Counter is running really well and either both it and my signal generator are off by the same amount or it is very close to being in adjustment.
Mental note - don't use your finger to test the temp as the heatsink is at 300V! - Don't worry I didn't do this.
Tom
