I have a 60" LCD TV from TCL which has sound but no screen (back light not working). TCL model 60D6 Power supply 40-L201W8-PWA1CG
Symptoms: when I turn on the TV, I do hear sound but the power led on the front does flash once and turns off.
The closest schematic that I could find was posted here
https://elektrotricks.blogspot.com/2018/04/tcl-les9b21-lcd-tv-power-supply.html it comes in three parts but all is one power supply. There are only two optocouplers signaling from cold (led) to hot (transistor). No optocoupler signaling from hot to cold (but schematic does have that).
I measure 12 V DC on the cold side but the back light power rail does not has any voltage. I took the power supply pcb out of the TV and inspected it with no signs of burnt parts or burnt pcb areas. I wired up the BL-On and P-On pins to 12V via a 4k resistor to trick it in powering up. The backlight rails turn on for a fraction of a second and it goes zero volt.
I measured the PCF chip FAN7930 which has 15V Vpcf (or Vcc) and even disabled it with no avail.
The Backlight chip OZ9976 should have on the enable pin 13, 2-5.6V DC for 'on' state and less than 1.0V for 'off' state. I measured 0V. Even when powering it up, it stays 0 volt. Pin 14, Vref should have 5V but measures 0.88V DC. Pin 8 VSEN should have 3.0V but measures 0V at all times. I have added a load to the backlight rail (small 20W led light) to ensure the Vsen get some power if a current would flow. I also measured the hot side stage for the backlight (MOSFETS). All good and even replaced them. Measured all the diodes and transistors for shorts (all good).
The PCF chip and Backlight chip have been replaced with new ones but same symptoms. However the power led on the from does not flash anymore but just turns off as usual when the tv was functioning well. So how should I proceed since the datasheet for the OZ9976 is worthless (one pager diagram
). I assume ENA, Vsen and Isen must be present to turn the back light on after a soft start. Anyone who has a good strategy to follow?
