Author Topic: 60v Battery charged but not enabled?  (Read 2810 times)
Offline marce002Topic starter
  • Country: ar
« on: March 07, 2024, 09:33:30 pm »
Hello
I have charged cell by cell this 16s10p 18650 doohan etanl battery because was not charging with its charger.. cells were 0.4 vol aprox... cells are now 3.9v stable so they are alñ 160 cells in good shape but bms does not allow to charge or discharge... what can be done in the board maybe or any trick fuse to reenable it? thks in advance
Offline Gyro
Re: 60v Battery charged but not enabled?
« Reply #1 on: March 07, 2024, 09:59:35 pm »
It probably has a microcontroller that has logged (and latched) the out-of-range cell voltages to prevent the fire risk.
Best Regards, Chris
Offline p.larner
« Reply #2 on: March 09, 2024, 04:26:49 am »
I think your best bet would be to replace the cells that were low+also the bms,if the cells were that low even if you charged them the capacity will be well low+a fire risk!!.
Offline Greybeard
« Reply #3 on: March 11, 2024, 12:24:55 pm »
There are BMS that blow internal non-resettable fuse in the failure case.
  • Country: ar
« Reply #4 on: May 08, 2024, 02:35:28 pm »
worked after reseting the bms thks
