Hi, all I can find on that pat number is that it is just a standard socket.
It is available here ->
https://wellgainelectronics.com/1397_3mFrom what I have seen, they are just normal sockets that have had the top edge sanded down to the top of the pins. Also they have had a cut-out made in the shell to slip over a SMD cap on the mainboard.
Some sockets may also need some plastic removed from the inside flat area so the socket sits flat on the chip.
I have one of these and have found the whole arrangement very susceptible to poor connections.
I found that it makes a better fit if you use desolder braid on the edge of the CPU pins to remove all the solder that may have wicked up during the original soldering process. (clean pins thoroughly with PCB cleaner)
When installing the board, take the main PCB out of the case and press both together to make the best fit (with it in the case the PCB bends and it will never go together properly.)
Then (pressing on the center of the socket) grab the right side of the ACA620 PCB and move it slightly (parallel to the main board) towards the keyboard connector, jiggle it back and forth a few times (this will seat all the pins that may not have a good grip on the chip) Now test the system, if all good bolt it down using the supplied mounting hardware and re-install into the case.
Note: these things cook at ~70c if not cooled, add a small 5V fan (take pwr from the crystal) see pic
