Author Topic: 7 Segment LCD display  (Read 573 times)
Offline hpmaximTopic starter
« on: November 13, 2021, 10:21:56 pm »
I have a radio transceiver with an LCD which is having faded and missing segments.  The interesting thing is, the segments are not behaving consistently -- that is the behavior of a segment can depend on the other segments.  Unfortunately, I know I was the cause of this.  The LCD is mounted on a board with an encoder, a microcontroller, and a few other things.  The board is then glued into an aluminum housing, and the house housing is screwed into the radio chassis.  I removed the housing, and then sprayed Deoxit D5S-6 through a hole onto the front side of the board with the encoder (and the LCD) on it.  Unfortunately, that hole (a few mm in diameter) is really my only access unless I remove the silicone glue and hope that's all that's holding it in.
I'm sure the LCD is something custom.  I suspect the radio itself is a circa 2000ish design, and this particular unit was probably manufactured in the mid to late 2000s.  The display is backlit with the format:
xx
xx.x    1XX.XX
Where the "----" is a solid line and "x" is a 7-segment, that's smaller than "X".  Soooo, total of 69 addressable segments?
Since I  haven't been able to remove the board it's hard for me to find markings on the display or even how it's mounted (soldered versus zebra foam).  The only thing I tried (in case not all the fluid had evaporated) was to stick it in a plastic bag, and then bury it in a sandbox, and then stick the sandbox in my oven at 75C for 12 hours.  I figured this would gently raise the temperature up enough to dry accelerate evaporation without being hot enough to risk damaging anything.  It might have improved things, but I can't really tell...  The display goes through a self-check on power up and indicates on all segments, and they all work when in this mode.
Re: 7 Segment LCD display
« Reply #1 on: November 15, 2021, 02:21:43 am »
It looks like the Deoxit deformed the zebra foam a bit and it hung out the end of the bezel that was pressing it in place.  When it did that, it bent away from the LCD a bit.  If anyone knows where to get the display, I'd be very curious.
