Hi again.
As for replacing the original MSO500 fan, with a Noctua, it could be a good solution to reduce internal noise.
But it does not resolve the issue of internal temperature, the lack of heat exhaustion by convection, and the lack of forced ventilation to remove the hot air generated internally.
This issue of internal heat may shorten the lifespan of the MSO5000. And cause poor contact in electronic components, soldering, early failures, etc...
In my case, on my MSO5074, I understood that it is better to have more noise than to have high internal temperatures.
During the factory warranty, I thought it was best not to break the warranty seal, and to install an external fan, on the right side of the rear cover.
In this case, I took a common CPU-PC SMPS fan. It uses 12VDC, and is 10cm diagonal, and I use an external 12V power supply on the MSO5000.
The noise increased, but the internal temperature decreased a lot.
To attach the fan, you do not need to drill or damage the back cover. I attached 3 fan mounting tabs with 3 pieces of hard wire, with jacket, #12AWG. (see the photo).
When I turn on the MSO5000, I already turn on the external fan.
The external fan is located exactly over the internal SPMS, and can also suck in the hot air generated there.
I recently saw in another topic here on EEVblog, that the SMPS of the MSO5000 does not have a 12VDC voltage output:
https://www.eevblog.com/forum/testgear/rigol-mso5000-power-supply/msg4939123/#msg4939123In the future, I intend to install internally, over the MSO5000's SMPS ventilation holes, a 5VDC fan, with the largest diameter and smallest height possible, to forcefully exhaust air through the holes on the right side of the rear cover.
An ingenious solution is RIGOL, remaking the mold of the rear cover, and placing ventilation holes in the top and bottom, and installing a forced exhaust fan over the SMPS of the MSO5000.
And, provide free of charge, under warranty or out of warranty, the new rear cover and the new fan, for users purchasing this MSO5000.
That's a lot of thinking and acting for an international manufacturer of measuring instruments.
