Author Topic: power supply _ IGBT testing  (Read 423 times)
Offline abode091Topic starter
  • Country: ae
« on: October 13, 2023, 06:15:07 am »
Hello,
I'm repairing a power supply that has multiple IGBTs.
The shorted IGBTs that has C-E resistance of couple Ohms are easy to know that they are broken.
But what about those that have C-E resistance in the Kilo Ohms instead of Mega Ohms, should I consider those dead, damaged or correctly functioning?
Note: the original C-E resistance is around 2.5 MOhms, now its around 8.5 KOhms.
Thank you in advance.
Abd
Online jonpaul
Re: power supply _ IGBT testing
« Reply #1 on: October 13, 2023, 07:28:07 am »
A resistance meas at a few mA in an ohmmeter is not a reliable IGBT indicator.
Also, shorted switches often are due to a more serious load or driver fault.
Remove all the IGBT devices and test on a curve tracer or HV lab PSU.
Place dummy loads on each driver and check driver outputs.
Bon Chance
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: abode091
