Hi jacamo,
My answer comes a bit late as you already successfully repaired your unit.
And luckily you've got the schematics, which, of course, is of great help.
As you are located in the USA, I assume that you use 120VAC line voltage to power the gear.
HMI/HQI lamps electronic ballasts are not that easy to understand because, functionally speaking, it is an AC current source plus a high-voltage igniter. The arc lamps need a significant warmup time (up to 5 minutes) which has to be very carefully monitored. Once at maximum brightness, the arc voltage for many usual bulbs is about 95VAC.
So it's not easy stuff and this unit doesn't make an exception : the 'power section' consists of a mains filter, an inrush current limiter (K2), then a voltage doubler (K1), followed by two parallel buck regulators (Q4, Q5) and finally a full H bridge forged around four IGBTs.
And you also made the correct assumption : U1 plus T1 form an auxiliary power supply and if not functional, the unit won't work correctly.
Rewinding T1 which is probably a ferrite transformer, is definitery a significant achievement. Quite all of them are custom made : so even if you ask the manufacturer of this electronic ballast, you might not be able to buy a replacement part. At best, he will be able to provide the complete 'power board'.
And yes, for this kind of gear, you can replace the UC2844 with an UC3844.
Powering the UC3844Have a look at
Figure 8-7 for a ballpark view on how it works.
On your schematic, the UC3844 starts when the voltage across C22 >= 16V : the current comes from the 325V rail via R10.
Once running, the UC3842 receives its power supply from the 5-6 winding of T1, via D8 and D7.
Output voltage regulation and calculationThe UC3844 is a current-mode PWM controller which also has a voltage feedback loop, as explained at
§ 'Pin 2 Error amplifier inverting input'.
The internal comparison threshold is 2,5VDC (= VREF/2).
In your circuit, the output voltage probing is done by R24 and R21. I went through several datasheets and appnotes talking about those PWM controllers. It's a bit shabby, but it seems that the formula for calculating the output voltage is not provided anywhere. You have to analyse the application examples and recalculate the formula. Here it is, with the actual parts references used in your schematic :
Output voltage = [1 + (R24/R21)] * 2,5 = [1 + (24,9 / 4,99)] * 2,5 = 5,99 * 2,5 = 14,97V which is about 15VDC as expected.
As you measured 16.3VDC, and even if it seems not to harm the other sections of the electronic ballast, there might still be a small issue pending : you should actually be very close to 15 VDC.
As it's not that bad, you may leave it as is, or if you want to dig further, go on reading below.
To go furtherIf you could provide the schematics of the control(s) board(s) (connected to P1, P3 and P4) and the igniter board (connected to P2), this would help to validate if 16.3VDC as AUX power value is acceptable or not.
16.3 VDC is most of the time a still acceptable value for a 15VDC power supply, but it should be rock on 15VDC : as it is not the case, this might hide some ringing or even an U1 hiccup mode or IC failure.
As there's a regulation loop inside U1, the fact that you perhaps did not exactly wind the same amount of turns for T1 should not influence the actual output voltage : the loop shall be able to compensate. You are right, the UC3844 is really not easy to understand because of its combined current and voltage steering which shall improve its loop stability. But it would be overkill to validate the loop stability of your unit : it requires very specific and expensive test equipement.
The AUX power supply is not insulated from the mainsEven if U1/T1 looks like a flyback power supply, the 15V rail is not isolated from the mains because the T1 secondary is tied to the ground. And the latter is derived from the mains via BR1 pin 4.
This means that when this gear is powered, you should only use a multimeter to probe inside. To avoid any electrical shock, an isolated oscilloscope or a high voltage differential probe would allow to keep you on the safe side, while looking for an in-deep view of what's going on.
R19/C19 sets the oscillating frequency to 78.2 kHz (calculated value). But for the UC3844, this value has to be halved, so it is 39.09 KHz.
Other checksNow that T1 is repaired, check again U1s power supply (pin VI = red probe, pin GND = black probe). It should be between 11.5VDC (because below, the UC3844 detects instantaneously an 'UVLO condition' and restarts/reboots) and 20VDC, which is the D14 zener voltage. You might want to replace C11, C12, C17 and C22 and see if it helps.
Then check VREF and it should be 5VDC
Then check VFB and it should be 2.5VDC
With the unit turned off, also check the resistance value of R21 and R24. When measured 'off-circuit' (= one leg lifted), they should match within 1% of their indicated values.
Also check D7 and D8.
Please report the values you measure.
