Author Topic: 852d+ Cheap Repro Proactive repair questions  (Read 1381 times)
Offline MrWizerdTopic starter
« on: April 04, 2017, 07:25:49 am »
So I have the 852D+ Rework station (hot air and solder)  I had got it for very cheap and I have done some reading and once got a search to work and give me some threads on here that eluded to the possibility that someone somewhere is working on replacement boards that are uC based.  I can not find them and if anyone knows where they may be or has a link to a project page that I can read up on I would greatly appreciate it.  That being said I apologize for this post as I know that it is probably drudging up things that have been posted before but as I said the search function would just not work for me no matter what I tried keeps saying report to the admin.  I will likely do so if it persists.  My current plan is as follows
Make sure unit is properly grounded and fused.
Add a switch that will cut power to the unit so I can turn it off all the way after the cool down cycle (to prevent random triac failures)
Do a general safety check and repair anything that appears completely unsafe that is in my power to fix,
And make sure that transformers and such are all properly secured.
There are a few other things I am sure to run into.  I did however have a question, some of the things I have heard is that the 8A TRIACs the bt137 https://www.digikey.com/product-detail/en/ween-semiconductors/BT137-600,127/1740-1026-ND/1154768 tend to blow out.  I found some BTA12's that are 12A TRIACs http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=222825388&uq=636257350278275154 though the gate trigger voltage on these is 1.3V instead of 1.5V my thought was that I could use these possibly as it has been suggested by some they are being driven almost at 100% current limit and thus are over heating.  I thought changing them to a higher current rated one may help with that but I don't know much about TRIACs and if this is a possible solution.
I suppose that question is a mute point if anyone has a set of replacement boards and firmware for said boards for this in the works, especially if I can help with the testing for such items, I can have the boards printed and build them up and get to testing it out, but I can not find anything when I search or 852D+ rebuild or DIY replacement or any other way I thought to search.
Anyone have any ideas, suggestions, links?
Again I apologize for not being able to just use the search fuction.
Little beats big when little is smart, first with the head then with the heart ~P.K. Power of One
Offline SoundTech-LG
