Yes it is possible and I have not pulled out any of the modules for an inspection, other than the CPU. Since it "healed" itself I measured the actual current draw on the supply. It was well under the supply's rated output:
For 5.2V, rating is 8A, measured 4A
on 15.5V, rating is 3A, measured 1.4A
on -15.5, rating is 2A measured 0.6A
on +12, rating is 3A, measured 1.46A
The impossible LED combination of red, no green would have to point to the power supply if my recollection of the LED state is correct. But I will pull the other boards and inspect.
BTW, this particular supply has an Agilent label on it, and all the PCB have Agilent etched onto them, and I see some components with HP style part numbers xxxx-xxxx. It appears to be a match to the publicly available schematic for that power supply. Pretty decent design I might add. More complicated than necessary, partly due to each output being fully isolated. They all have a common ground at the backplane.
CL
