Thanks for the replies and advice!
Get the manual.
Check vertical gain calibration of channel 1 and 2.
There is also an x gain (sweep width) to check.
I have the operation manual (
https://nscainc.com/wp-content/uploads/pdf/H_V1050.pdf) but could not find anything that helped, though a lot of it I could not understand. I have checked the calibration several times and it appears to be okay. Even after checking the manual I am not sure what you mean by checking the x gain sweep width, sorry.
Have a look 1kHz signal.
I tried this on each channel, channel 1 was displaying it very oddly, making a strange double sine wave thing, very cool looking but probably not correct.
After leaving it for a bit, channel 1 very suddenly displayed it correctly (probably). The trace wasn't moving at all, unlike in the gif.
I don't know what this means or if it's normal, but I do hope this is useful.
No expert, but I think I would first use a multimeter
to check the voltages of the two channels.
I currently do not have a multimeter, but I could maybe find one. I'm also not sure how to check the voltage of the channels but could probably figure it out.
Try swapping the inputs
After swapping them, I had the exact same result, but thank you for the suggestion.
Please tell me exactly what you were expecting to see? If your answer is a single thin line at a 45 degree slant then you obviously have phase shift between X and Y. Is one A.C. coupled and one D.C. coupled? If you reduce the vertical gain it looks like you would get a circle. It appears the vertical gain is currently about 2X the horizontal gain.
I was expecting to see a circle similar to the image below (Not my scope/image)
As for the AC/DC coupling, both of the channels are the same cable, so coming from the same output on my PC. I am not sure whether it is AC or DC coupled as when I change the setting on the scope, it displays exactly the same thing. I have read that a line-out port from a motherboard is likely AC coupled.
I tried changing the vertical gain and it was more circular but still far from normal, almost like a circle with a dent in it.
Why would you expect a circle??? You need 90 degrees of phase shift to obtain a circle. Is your laptop audio client capable of variable phase shift? Normally Left and Right outputs would show no phase shift and you should get one thin slanted trace at 45 degrees going from lower left to upper right. We need a bit more info about the signal generation. How are you controlling phase shift? It looks like your signal is whacked out, not the scope.
There was 90 degrees of phase shift (I think), I followed this guide
This image shows a 1kHz wave slightly adjusted so there should be a 90 degree phase shift (I have also tried adjusting it to see if it'd help but it always looks wrong). If you need more information regarding the signal then please let me know.
Nice old scope,
I have mostly had imperfect Lissajous traces on old equipment. Everything has to be very well aligned and the input leads need to be near identical to get good lissajous pattern.
Here is some suggestion:
Put the same signal, perhaps a ONE KHz signal on both the A and B Channels using your leads. Or use Identical length BNC leads. See if they can very closely align with one another using vertical adjust to put them on top of one another and then amplitude. Once you do this then try the A vs B and you should get a 45 degree line as the Capt states. If you cannot get the same signal to be identical in both separate traces, you will not get the desired pattern. Your pattern suggests a 90 degree difference
wikipedia has nice diagram of different patterns
https://en.wikipedia.org/wiki/Lissajous_curve#/media/File:Lissajous_phase.svg
edit: Please Adjust your probes using the compensate adjustment before doing anything else.
Thank you, I will give this a shot and read that Wikipedia page as soon as I get the chance and let you know how it goes. Would the compensate adjustment be the small red knob on the VARIABLE VOLTS/DIV knob? I am quite new to all of this and not great with terminology, sorry.
Thanks again for the advice everyone
(Quick edit, I have realised that the "gif" is now a static image, it is meant to show that the trace(?) is moving rapidly to the right, sorry)
