Author Topic: A few general questions about thermal pads and copper tarnish  (Read 1016 times)
Offline skyhawkTopic starter
This is the controller board for a 2 year old hard disk drive.
The drive started displaying odd behavior and failing self-tests, so I was about to throw it in the garbage when I figured "let's take a look at the controller board for shits and giggles"
2 "repairs" later using a boxcutter and a white eraser, and the drive is now back in service, and appears to be operating fine  :-\
I've got four other drives of the same make and model, and I have now performed the same "maintenance" on them as a preventative measure. Am I being paranoid or are thermal pads supposed to have the plastic cover removed before they're pressed onto something?
Offline helius
Re: A few general questions about thermal pads and copper tarnish
« Reply #1 on: July 13, 2018, 05:22:46 am »
It's a little hard to tell, but that might be a Sil-Pad: a heat conductive silicone spacer.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: July 13, 2018, 01:45:39 pm »
Yes, the plastic cover is supposed to be removed.
Seven Transistor Labs, LLC
« Reply #3 on: July 13, 2018, 10:09:57 pm »
Should I be concerned about the fact a shiny new drive (made probably about 2 years later) has the exact same plastic on the thermal pad?
Offline T3sl4co1l
« Reply #4 on: July 14, 2018, 08:30:26 am »
Probably not. It's been working for them so far...  :popcorn: :-DD
