Electronics => Repair => Topic started by: skyhawk on July 13, 2018, 03:40:56 am
This (https://imgur.com/a/aOrdSlj) is the controller board for a 2 year old hard disk drive.
The drive started displaying odd behavior and failing self-tests, so I was about to throw it in the garbage when I figured "let's take a look at the controller board for shits and giggles"
2 "repairs" later using a boxcutter and a white eraser, and the drive is now back in service, and appears to be operating fine :-\
I've got four other drives of the same make and model, and I have now performed the same "maintenance" on them as a preventative measure. Am I being paranoid or are thermal pads supposed to have the plastic cover removed before they're pressed onto something?
It's a little hard to tell, but that might be a Sil-Pad: a heat conductive silicone spacer.
Yes, the plastic cover is supposed to be removed.
Tim
Tim
Should I be concerned about the fact a shiny new drive (made probably about 2 years later) has the exact same plastic on the thermal pad?
Probably not. It's been working for them so far... :popcorn: :-DD
Tim
