Looks like a major project, good luck.
I'd do a full disassembly and clean, starting carefully with a stiff plastic scraper to dislodge as much corrosion as possible. Then the usual cleaning procedures, brushing, washing, IPA, etc. Get it spotless.
Check the Restoration thread on this Repair board for ideas.
Every socketed device and connector will need to be pulled and leads/pins checked for corrosion.
Presets and pots, even switches may be stuffed
mark the setting on each one, remove and check for correct resistance and estimated wiper resistance, exercise wiper if necessary and replace presets as required.
Inspect ALL with good light and magnification for ANY faults: traces, solder joints, cableing, inter-connects etc
Take plenty of photos.
Expect anything, this project might be a REAL test for you.
Again, good luck.
