Author Topic: A new soldering and desoldering station  (Read 4813 times)
Offline akis
« on: April 22, 2016, 07:27:29 am »
After a bad experience with the previous station which uses a 5-pin plug but only 3 wires as the soldering iron does NOT have a thermocouple (the extra pins on the plug are to make you think you are buying a great machine), I am looking to buy a new station. I was also looking for a desoldering iron, never used one, I was hoping it would be like an ordinary iron except it would incorporate some sort of vacuum pump to suck the melted solder away?
Offline Rasz
    • My random blog.
Re: A new soldering and desoldering station
« Reply #1 on: April 22, 2016, 06:39:12 pm »
what? post a picture of your fake 5 pin iron please
even the hobbyking 16euro 936 clone does proper temperature control
Offline nanofrog
« Reply #2 on: April 22, 2016, 07:29:15 pm »
As per a desolder iron, in it's most basic sense, it's a heated hollow tip that gets a vacuum applied when triggered (hand operated squeeze bulb, or foot switch/iron switch that operates either a electrically driven vacuum pump or a Venturi tube that's attached to compressed air). Hopefully, there's temperature control tied to the heater.  :P
For specifics, namely any kind of recommendation, what are you wanting to do exactly for desoldering (PTH?, SMD?, both? and how much?)?
And what's your budget?
Offline akis
« Reply #3 on: April 22, 2016, 07:49:39 pm »
Sure. As you can see there are only two wires into the soldering iron and on the plug side two pins have been shorted together...
Offline akis
« Reply #4 on: April 22, 2016, 07:52:56 pm »
I do not do SMD yet. Maybe never. But on occasion I need to remove components and it is hard/impossible to operate and use the old fashioned vacuum desoldering tool. You'd need an extra pair of hands to try and hold everything together and even then ...
Offline nanofrog
« Reply #5 on: April 22, 2016, 09:44:01 pm »
I'm not sure if this statement ^ is primarily referencing SMD or PTH, I presume you meant the latter and will start on that premise. I'm not sure if it's technique, lack of a good work holding vise, solder sucker, or some combination that's giving you the biggest hassle. :-// Might have some tips with more specifics (easier on the budget vs. desolder station too).  ;)
FWIW, I found I use my hot air station far more frequently than my solder sucker. :o ;D Besides, a hot air station and a good pair of tweezers/pliers can even be used for PTH component removal (rather nice on SIP or DIP). You'll still need to clean things up with braid and/or a solder sucker of course, but you'd have to go through a substantial amount of braid before it would add up to the cost of a desolder station.  :-DD
Even the number of uses you can find for hot air might actually surprise you. Heat shrink probably being the most obvious, but other things like adhesive removal (including mastic & labels), paint removal, softening up screws that have too much thread locker on them, massaging plastic enclosures to fit a project if say one capacitor is 1 - 2mm too tall ( :palm:), ...
So unless you're doing a lot of PTH desoldering, I don't see it as the best use of lab funds.
If you do need a desolder station but don't have a small fortune to spend, perhaps you might consider Hakko FR-300 (would expect better performance than say a Zhongdi desolder station), if you'd be OK with the all-in-one gun style format.  :-//  Otherwise check out reviews of the Zhongdi ZD985 (review & teardown thread).
Hope this helps.  :)
* Thinking in terms of ability to develop sufficient vacuum pressure, is easier to clean (solder doesn't solidify in the tube before reaching the catch chamber), and can easily get spares & consumables.
Dave even covered it in Video #542
« Last Edit: April 22, 2016, 09:47:18 pm by nanofrog »
Offline Rasz
    • My random blog.
« Reply #6 on: April 23, 2016, 04:24:03 am »
aaaah, sensor is in series with the heater, station pauses heating and measures resistance, this is less typical, not a direct hakko ripoff, type of heater
Atten At936b, AT201D, AT938D all use this
so do atten clones/rebrands like Conrad TOOLCRAFT ST-80A, Tenma 21-10120/21-10115
so does your clone of Atten AT938D
it is absolutely ok
looking at the picture im guessing tip is the problem, get a big flat one, or concave soldering tip (ones meant for drag soldering), plus a secret to good desoldering is adding more fresh solder first
Offline akis
« Reply #7 on: April 23, 2016, 07:48:33 am »
it is absolutely ok
Well, it is not working very well. The temperature is not what it says and fluctuates +/-50C - whatever it thinks measures it does it badly. I guess, that there is no sensor in series. Rather some "genius" has noticed that the heater's resistance increased (or decreased) with temperature and thought "hey we can save a NTC resistor as well as two wires inside the cable, hurray!"....
Offline Rasz
    • My random blog.
« Reply #8 on: April 23, 2016, 07:53:17 am »
no, more likely your unit is defective
return it, or open it up if you cant return it, we can help you fix it
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #9 on: May 21, 2016, 03:43:16 pm »
for me ,a fan regulator with triac changed to heavier one along with non contact thermo meter has been enough for me
plus, I use multiple irons. cause high thermal capacity irons are heavy and low thermal capacity irons sometimes are unable to melt solder even when connected directly
